Tuesday around noon our friend Mike came up to build a 12 foot diameter wind turbine. We had the parts water jet cut in advance. Mike made a very nice new plastic mold and brought that with him. It took basically a day and a half to knock this one out, it came out nicely!
Pictured above is the back side of the alternator. This is about the same as the last few 12 foot turbines we've built, but we did away with the square stator and built a better stator bracket. It's a fairly robust machine I think.
Pictured above is another shot of the same machine. As with the last few we've made....
The magnet rotors are 15 inches in diameter. Each rotor contains 16 N42 grade magnets, 2 inch diameter x .5 inch thick. It's a 24 Volt machine. In the past we've wound these with two strands of 13 gauge wire in hand, 35 turns in each coil. This time we used 4 strands of 16 gauge in hand. The coils came out much nicer... but a bit small, we could've fit another strand in there easily. The stator on this machine is .625 inches thick and it reaches 25VDC at 120 rpm (which is the same as all the other 12 foot machines we've made).
I've posted the above graph before. We made this last July at a workshop in MO. The black line represents power at the shaft from a 12 foot diameter blade, assuming cP of .25 at sea level. The blue line is based on a few data points of measured power into the alternator (power required to drive the alternator while it's hooked to batteries) - we measured foot pounds, and rpm. The red line is also estimated but based on more data points... and that is the power that we got out of the alternator. On the X axis we have wind speed, and rpm - assuming a constant TSR of 7 (which is not very realistic but fun to think about I guess).
A few weeks ago we installed an APRS data logging anemometer on our neighbor Toms tower at 50' in height. The unit also logs voltage and current. The graph above is from 10 hours last Monday night. Our peak gust that night was about 60 mph. Each data point represents a 1 minute average. This is in the mountains, the turbine is at 60 feet - it's a turbulent site to be sure. I would love to see how it looks on a 'good' wind site. Fun stuff anyhow - looking at this, the machine doesn't look terribly efficient, but it is definitely within reason and I expect it would look better on a less turbulent site. I can't wait to get more data... on a windier day so we can see the full power curve after it's furling more. This machine is basically identical to the 12' turbine we built this week.
