Which blades | 2 comments (2 topical, editorial)
Re: Which blades (none / 0) (#1)
by hvirtane (hannu_markus_virtanen(at)yahoo(dot)com) on Tue Oct 7th, 2003 at 09:04:00 AM MST
Hello,
I'm sorry I've got no idea, which blades are
the better ones for you.
But I wanted to know the material and the production
method of the blades. They look to be made of aluminum...
Re: Which blades (none / 0) (#2)
by wpowokal on Tue Oct 7th, 2003 at 07:57:06 PM MST
The blades are made of sheet metal, they mount on an aluminum spider and have a folded stifener over the spider inside the blade. Blades are spot welded together on the join and bolted to the spider with about 9x1/4" gutter bolts.
Spider can be seen in this pic, this particular blade has probally been made by its previous owner who used pop rivets.
regards Allan
http://66.140.203.100/gallery/allan/bent_blades
Which blades | 2 comments (2 topical, 0 editorial)
