Front Page
[Homebrewed Electricity
(wind)
(solar)
(hydro)
(steam)
(controls)
(storage)
(mechanical)
Classifieds
Site News
Everything
Newbies
[Remote Living
(housing)
(heat)
(light)
(water)
Rants & Opinion
Diaries
Our Products
Here are the plans to make PVC Pipe Props
31
comments (31 topical, editorial)
Re: Here are the plans to make PVC Pipe Props
none / 0
#12
by RobD on Wed Nov 12th, 2003 at 04:09:47 PM MST
User Info
http://www.dsgnspec.com
I have a couple of pieces of 4" diameter by 1/4 inch thick aluminum electrical conduit from an industrial site. I don't have enough to make a set of blades but some of you may have access to this stuff. I like the idea of fiber glassing over a form. If you look at the Air 403 blades there isn't much material so it should be hard. Trouble is I hate working with the stuff!
I think I'm going to try sheets of veneer backing criss-crossed on top of the PVC. It comes out like aircraft plywood, thin and strong. You can use poplar which is usually used for banding on burls in veneering. It's cheap and you can run a strip of aluminum HVAC tape over the leading edge.
Just some thoughts.
RobD
31
comments (31 topical, 0 editorial)
create account
How to use the board
FAQs
search the board
Google search the board
Old Otherpower Board
