Here are the plans to make PVC Pipe Props | 31 comments (31 topical, editorial)
Re: Here are the plans to make PVC Pipe Props (none / 0) (#13)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Wed Nov 12th, 2003 at 04:43:23 PM MST
 When I refer to angles here it is the angle of the face of the blade to the wind. If I want a 45 degree angle I just read out 45 degrees on the protractor. If I measured the angle relative to the center of the void pipe I would be reading 90 degrees for the 45 degree angle that I want. It was just less confusing to measure the angles like I did, and also there is not actually a point to measure from in the void eather.
 As for a table of the blades I've constructed ,  I am just getting started. The picture above is the only blades that I've made. Zubbly basicly invented them, an I have just modified the design to work better and be easier to build. Call them Zubbly blades with the Woofer Mods.
 I have questions that I want answered too . . .
How may RPMs will they take ?
What would the failure mode be ?
How long will they last in the Sun, Rain & wind ?
Any way to coat them to get them to last longer ?
How efficent are they really ?
Will they break or just bend and spring back ?
Etc...
}=- W o o f -={
Re: Here are the plans to make PVC Pipe Props (none / 0) (#17)
by Jerry on Thu Nov 13th, 2003 at 10:26:32 PM MST
Hey Woof I like that Zubbly blades with Woofer mods.
Has a femilier ring to it.  Go Plastic people.
Airheads Page
Here are the plans to make PVC Pipe Props | 31 comments (31 topical, 0 editorial)
