Here are the plans to make PVC Pipe Props | 31 comments (31 topical, 0 editorial)
Re: Here are the plans to make PVC Pipe Props (none / 0) (#16)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Thu Nov 13th, 2003 at 12:23:49 PM MST
When you cut a PVC Prop you will see thier strength. Are you really sure that doubling the thickness for strength is nessesary. However I like the Idea because it gives more Thickness to make a better Airfoil.
}=- W o o f -={
