Here are the plans to make PVC Pipe Props | 31 comments (31 topical, 0 editorial)
Re: Here are the plans to make PVC Pipe Props (none / 0) (#3)
by kmitchel on Tue Nov 11th, 2003 at 09:05:12 PM MST
Thank you for contributing your work on PVC props, I've found the discussions rather fascinating.  The process seems alot more elegant than hand carving wooden props.  Anyhow, would it make a little more sense to describe the hub and tip angles relative to the center of the pipe?  At least for construction purposes.  Would it be possible for you to publish a table of blades you have constructed, including tip and hub angles prop length, and pipe diameter with a description of performance or character.  With enough variations it should be possible to determine guidelines.
Re: Here are the plans to make PVC Pipe Props (none / 0) (#13)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Wed Nov 12th, 2003 at 04:43:23 PM MST
 When I refer to angles here it is the angle of the face of the blade to the wind. If I want a 45 degree angle I just read out 45 degrees on the protractor. If I measured the angle relative to the center of the void pipe I would be reading 90 degrees for the 45 degree angle that I want. It was just less confusing to measure the angles like I did, and also there is not actually a point to measure from in the void eather.
 As for a table of the blades I've constructed ,  I am just getting started. The picture above is the only blades that I've made. Zubbly basicly invented them, an I have just modified the design to work better and be easier to build. Call them Zubbly blades with the Woofer Mods.
 I have questions that I want answered too . . .
How may RPMs will they take ?
What would the failure mode be ?
How long will they last in the Sun, Rain & wind ?
Any way to coat them to get them to last longer ?
How efficent are they really ?
Will they break or just bend and spring back ?
Etc...
}=- W o o f -={
Re: Here are the plans to make PVC Pipe Props (none / 0) (#17)
by Jerry on Thu Nov 13th, 2003 at 10:26:32 PM MST
Hey Woof I like that Zubbly blades with Woofer mods.
Has a femilier ring to it.  Go Plastic people.
Airheads Page
