Here are the plans to make PVC Pipe Props | 31 comments (31 topical, editorial)
Re: Here are the plans to make PVC Pipe Props (3.00 / 0) (#30)
by ghurd on Tue Aug 23rd, 2005 at 01:19:07 PM MST
I think the 45' degrees is for reference.
I use a piece of poster board, mark out everything, then set the pipe on the poster board and marked the pipe.
I use a 6' piece of angle aluminium set on the pipe to mark the center line on the outside of the pipe.
Don't stray too much from their design. The more I got away from it, the worse everything worked, regardless of diameter. With a straight leading and trailing edge at least.
Here are the plans to make PVC Pipe Props | 31 comments (31 topical, 0 editorial)
