hornet blades got about 800 watts 35 mph | 10 comments (10 topical, editorial)
Re: hornet blades got about 800 watts 35 mph (none / 0) (#6)
by desertratjack on Tue Dec 9th, 2003 at 10:55:00 AM MST
I have the 6V and 12V hornet windmills. They both create the same noise around the same windspeed. I bought the 6V one because I thought it would drag the prop down below the noise speed. No luck. I wet sand the 6 blade hornet blades to 400 grit. Maybe the hornet blade tips deform at higher loads to make noise?
Please let me know is you notice any hints on how this noise problem.
Jack
Re: hornet blades got about 800 watts 35 mph (none / 0) (#7)
by Jerry on Tue Dec 9th, 2003 at 10:27:02 PM MST
Hi Jack
I sent you an e-mail this morning to the address you said to use but AOL said it didn't go through. Do you have an e-mail address that works?
Airheads Page
Re: hornet blades got about 800 watts 35 mph (none / 0) (#8)
by desertratjack on Fri Dec 12th, 2003 at 09:20:37 PM MST
I'm not on AOL.      jacknl7s@hotmail.com
Re: hornet blades got about 800 watts 35 mph (none / 0) (#9)
by Jerry on Sat Dec 13th, 2003 at 07:31:45 PM MST
Yep Thats the address I sent it to as you sugjested but it didn't work.
Sorry. JK TAS Jerry
Airheads Page
Re: hornet blades got about 800 watts 35 mph (none / 0) (#10)
by desertratjack on Thu Dec 18th, 2003 at 05:42:05 PM MST
send it again
hornet blades got about 800 watts 35 mph | 10 comments (10 topical, 0 editorial)
