Tower Fun | 13 comments (13 topical, editorial)
Re: Tower Fun (none / 0) (#7)
by RobC on Wed Dec 24th, 2003 at 10:13:52 AM MST
Looks great I like it. Definitely got to try one myself one of these days.
RobC
Re: Tower Fun (none / 0) (#8)
by Old F on Wed Dec 24th, 2003 at 11:26:53 AM MST
Well Rob
If there is enough interest I try to put together a how to guide.
It a wide open field not much has been done with it in 30 years.
And it to good of a design to let fade away.
Old F
Have so much fun it should be illegal
Re: Tower Fun (none / 0) (#9)
by Kevin L on Wed Dec 24th, 2003 at 12:51:16 PM MST
Old F
A simple 3 inch diam 1/4 in wall steel pipe will handle a 200 lbs compression load.  If you plan to use guy wires anyway, why go to all to constuction trouble and increased cost?   Entertainment value?
Re: Tower Fun (none / 0) (#11)
by Old F on Wed Dec 24th, 2003 at 04:59:50 PM MST
Kevin
Pipe towers are a low cost way to go .
But I want to get a way from having  to transport 20 foot section of pipe or do any welding in
the field if I want to go higher.
I have help raise some pipe towers for antennas and if you don't dot your I and cross your Ts thing can get hairy real fast . A pipe tower is 100% dependant on the guy for holding it up and during raising and lowering . A more ridged structure makes life a lot easer. And we are talking
more than just  compression loads.
That's why I am working with 10 foot sections that bolt together.   I can easily transport the materials in my short bed pick up. And the finished 10 foot section weighs in at 41 pounds.
As for cost the conduit cost 14 dollars the angle iron was 5 cents a pound at the scrap yard.
 Now that I am set up I can knock out a 30 or 40 tower'  in a weekend or at most two.
 As I work mostly by my self I want things I can easily handle. I not getting any younger : )
Old F
Tower Fun | 13 comments (13 topical, 0 editorial)
