waste water heat recovery | 6 comments (6 topical)
Re: waste water heat recovery (none / 0) (#1)
by joe4324 on Sat Dec 27, 2003 at 03:09:58 AM MST
I love stuff like this,  If your warming up the cold water a little bit before it goes into the hot water heater you could be saving yourself a couple dollars a month, maybe a little more!
My only problem with systems like this is its hard for me to choose wich ones to use because you cant have them all.  eventually you'll have a plumbing nightmare!  :)
Re: waste water heat recovery (none / 0) (#4)
by wooferhound on Sat Dec 27, 2003 at 08:11:02 AM MST
Yes ,  I can see the water going through the shower water
 then up to tha attic to warm up some more
  then down to thw hot water heater to finish warming up the water
    Then to the shower and drained to start heating up the new water comming in. . .
}=- W o o f -={
