Tower wrecking | 11 comments (11 topical, editorial)
Re: Tower wrecking (none / 0) (#9)
by Demetri (corvettemach1@yahoo.com) on Mon Dec 29th, 2003 at 02:59:15 PM MST
If you've got easy access to a wrecking yard, go look at late '80's automatic transmission Hondas. The speedometer cable fitting on the transmission contains a hydraulic pump; you can see the two hoses coming out of it. I believe it is two bolts to remove the fitting. It can be chucked into a drill as a drive source, and I've had it to 150 psi without trouble. Not very many gpm, so it'd take some time, but something to consider. Hope this helps.
Demetri
Uncommon sense required.
Tower wrecking | 11 comments (11 topical, 0 editorial)
