Tower math ? | 5 comments (5 topical, editorial)
Re: Tower math ? (none / 0) (#1)
by kell on Wed Dec 31st, 2003 at 06:15:12 PM MST
The tower in the example has attachment point(s) 10 feet from the axis of pivoting. Yours has an attachment point 5.196 feet from the axis of pivoting, if I did the geometry correctly. Now if in the example dividing by 10 gives you the total lifting force at the attachment point(s), then for your own tower, dividing by 5.196 will give the total lifting force at the attachment point. But one point (the triangle vertex) will take all the force. The example tower has two feet attached to the ground, or a ten foot connecting rod attached to the ground or however it's built. And I hope your load figures are in foot-pounds, so that when you divide by feet, the final result comes in pounds, which are a unit of force. Only way it would make sense. Foot pounds are a measure of torque. Like if you apply 50 lbs force to a lever at a point 30 feet from the fulcrum you get 1500 ft lbs of torque. If the lever sticks out 10 feet on the far side of the fulcrum you get 1500 ft lbs divided by 10 feet = 150 pounds force at the far end of the lever. Why can't I get carriage returns on this posting?
Re: Tower math ? (none / 0) (#2)
by TomW on Wed Dec 31st, 2003 at 07:44:46 PM MST
Kell;
You asked:
The answer is because you need to set your comment posting format preferences to "auto format" and you likely have it set to "html formatted".
In case your not sure where that is it is between the Preview and Post buttons just below the text entry window. You can also set it in your user preferences.
Re: Tower math ? (none / 0) (#3)
by Old F on Wed Dec 31st, 2003 at 09:12:03 PM MST
Thanks Kell
The force is measured in foot pounds. Should have said that in the first post.
With that snag out of the way things are starting to make sense.
And the numbers are falling in to place better than I expected.
Tho I will add an extra 15 or 20 % as a safety factor.
 Looks like I am well on my way of meeting  my goal
A 30 foot tower and  from the of  looks things now  a free stander
Rated for an 8 foot diameter blade set in a 60 mph wind an supporting up to 200 pound
of machinery.
Now off to gather some  more data on strength of  materials
Kell many thanks till your better paid
Old F
Riding the learning curve and loving it : )
Tower math ? | 5 comments (5 topical, 0 editorial)
