Testing thrust loads on a tower | 5 comments (5 topical, editorial)
Re: Testing thrust loads on a tower (none / 0) (#1)
by jubalearly on Mon Dec 8th, 2003 at 12:26:39 PM MST
       You will have a combined thrust and weight load, so I don't think either of your approaches will work. A lot of the pole manufacturers have info on wind load calculations on their sites. These would be for sign and light poles where the exact load varies. I don't have any URLs for you but you might try the Rohm tower site and a google search for wind load etc. mentioned above. Good luck, HTH,       - Russ H
Re: Testing thrust loads on a tower (none / 0) (#5)
by desertratjack on Tue Dec 9th, 2003 at 11:07:56 AM MST
I think it is Rohn.
Testing thrust loads on a tower | 5 comments (5 topical, 0 editorial)
