Keep us posted on your output data when its together!!!
Have Fun Ed Have Fun! Windstuff Ed
The airgap is kind of a bummer, but on the bright side, the cutin speed came out exactly where I wanted it and the stator is a bit stronger/less flexible - which is good I think because it's large enough - and the coils all pretty much touch each other, that weakness in the stator was a concern. It came out this way because I used a bit more fiberglass than normal on both sides, and I heated the resin up a bit much before I started (and mixed it a bit too hot) so that by the time I was putting the top on my mould it was allready setting up. (I should've been more patient!).
Perhaps next time I'll have the resin go a bit more slowly and then perhaps I could get away with slightly thicker wire and a few less windings (maybe 4 strands of AWG 15 wire) so that resistance is a bit lower.
I wonder if, in your case there would be any advantage to using multiple strands (other than that they are a bit easier to handle). Would eddy currents in the copper be an issue with you, since youd be burying the windings inside slotted steel laminations? It seems the laminates might take care of the eddy current losses in your case.[ Parent ]
Have fun Ed Have Fun! Windstuff Ed[ Parent ]
Hi Ed.. I have to say, Ive not calculated this - but if we ignore the thickness of the insulation, that doesnt make sense to me... it should be the same shouldn't it? Except that - really large thick wire is harder to wind tightly, so I actually tend to think the opposite, It seems I can squeeze in a bit more copper this way, but I could be wrong.[ Parent ]
Then the group consencis was. Big wire , small wire the copper amount would be the same. I thought I could squeez more wire in with the small stuf and perelell the coils rather than siries? DA-NO?
Airheads Page
