Hydrogen motor conversion | 5 comments (5 topical, editorial)
Re: Hydrogen motor conversion (none / 0) (#2)
by desertratjack on Wed Dec 10th, 2003 at 08:23:23 AM MST
The indications are that hydrogen is a good fuel for gasoline engines with no modifications to the gas carburetion system is from hydrogenappliances.com
Perhaps starting them on gasoline and then supplimenting the hydrogen is workable.
Re: Hydrogen motor conversion (none / 0) (#4)
by Old F on Wed Dec 10th, 2003 at 04:15:34 PM MST
Geek
Running a engin on hydrogen should not be any harder than running one  on propane.
I think all you would need is a demand regulator for propane and a supply
of hydrogen at 12 psi to feed the regulator .
I did a duel  fuel conversion on my back up generator this summer I can run ether propane
or gasoline starts easy in cold weather on  propane .
 Check out this post  http://www.fieldlines.com/story/2003/9/1/82526/70829
It not hard to do.
Old F
Have so much fun it should be illegal
Hydrogen motor conversion | 5 comments (5 topical, 0 editorial)
