don't worry.
It happens to many people.
My late aunt's name was 'Hanna'.
By the way 'Virtanen' is the most common surname in Finland. Hannu is a quite common first name as well.
So there are hundreds of 'Hannu Virtanen' is this country.
If you want to correct it on the board, you can do it easily I think. You make the correction on the original, which you've got upload it with the same name as the original replacing the original. Then it is there?
- Hannu[ Parent ]
Best Regards,
troy[ Parent ]
