Flash steam | 39 comments (38 topical, 1 editorial)
Re: experiments? (4.00 / 1) (#31)
by Andrew (andrew@lookingglass.com) on Sun Jul 6th, 2003 at 01:04:20 PM MST
Your idea of iron is not a problem. First simply make a "half cast" of the chamber, and then forge it twice. On the inside simply weld or braze small iron bars. As many as you can. Next have one of the villagers mix up some clay or ceramic type mix. Simply paint the iron bars and the inside of the chamber as much as you can cover. Do this with the other half as well. Welding shouldn't be a problem if the ceramic has time to harden. Weld the halves together. For your water towers, gravity will be fine. Do not paint them black as you could get too much pressure that it could force open the intake valve prematurely. As for the efficiency. I don't think you can beat pv cells. This machine at MOST will be about 20% efficient. Simply because of the thermal losses of the chamber, the turbine only being pulsed by steam, and not continuous flow. (Probably compansate for this by adding a large flywheel.) The longer the chamber the better. A coil type chamber would be ideal. This is how I made mine. About 2 or 3 turns.
Now on the design....
Put the intake poppet valve right near the water towers (ball valve could work too). Add heat sinks (as much as you could machine or weld, etc.). When the high pressure steam shoots out both directions, it will head toward the chamber. It will approach the valve, and then cool off. It will draw a vacuum when cooling off forcing more water in the chamber. (The neat part about this design is it needs no water towers for pressure, it can intake the water straight up, vertically, which means that instead one could simply put the intake hose in a small pond or lake, etc) If you put the valve right next to the chamber it will not work like this. You WILL need water towers. As for your turbine.... A simple pelton wheel type turbine will be excellent. You will probably need access to a lathe, as balancing this will be a pain. (you are spinning at many tens of thousands of rpm) I got my little pelton wheel to about 22,000 rpm. Everything else looks fine. (if there is anything else)
-Andrew
Re: experiments? (5.00 / 1) (#32)
by Anonymous Hero on Mon Jul 7th, 2003 at 04:50:20 AM MST
I think if he returns to the smaller flash box and stays with solar mirror, it will again be 80% efficiency or higher. Also pulsing a turbine, instead of steady stream, is not going to be a problem for what he intends. You don't need 100,000 rpm, or even 22,000, to generate 1000 watts. At $3.50 a Watt (Solar Panels) that is roughly $3,500. If you can make this cheaper by keeping it simple you'll be better off than panels. Any needed valves can be found at a Boiler supply web site. You need nothing in the (small) chamber, no rocks or pipe. The air inside the chamber will be over 600 degrees. The water will not skate anywhere, the air alone will flash steam it. Cheers
Re: experiments? (4.00 / 1) (#33)
by hvirtane (hannu_markus_virtanen(at)yahoo(dot)com) on Mon Jul 7th, 2003 at 05:54:36 AM MST
Andrew:
You mean that after twice forged it will be easy
to weld? I will consult my friends, who work
for a very big foundry here.
Andrew:
As many as you can.
Don't you think we should fire the whole thing
in a kiln
after welded together?
Andrew:
valve prematurely.
Yes. One of the main problem will be to control the
pressures.
I'm thinking that we might make the chamber that way
that the steam starts flowing out fast
and even creates a bit
suction. If we make the chamber to expand towards
the turbine and make it like a spiral inside?
Andrew:
Yes I think that we have got two possibilities for the
design:
  1. a pulsing steam system or
  2. a continuous flow
system.
I'm trying to design this power system to be
as much as possible 'village technology',
'self-made'
so that the cost in money would be low.
PV cells you cannot make
in a village easily, so they cost money.
The cost will then depend heavily on the
salaries of the local hired people, like blacksmiths.
I'm thinking that some engineers in India, in Nepal,...
could try making something like these
in small villages there.
I agree that concerning how effectively we
are using solar radiation, good PV cells are
already hard to beat.
Andrew:
(Probably compensate for this by adding
You already made one???
You seem to be very fast.
Please describe more!
Andrew:
Add heat sinks
I agree that making a pulsing steam flow would
be easier to make.
Could you, please
describe a bit more your
'heat sinks' concept?
Andrew:
You think that a pelton wheel might work better than
a simple crossflow?
Are you running your pelton with this
steam system already???
Andrew:
Thank you a lot
for your very good contributions!
I've informed about this site some
of my friends in Nepal and in India , too.
Maybe some of them would start making
these things.
-Andrew
