Regarding your air compressor system you're trying to set up.....why not get rid of the air tank altogether? Use the engine's oil pump while it's running to charge the tank with oil under pressure at 30 psi or so depending on your oil pressure at idle. Just use an electronically actuated valve that you can open up while driving around to pressurize the tank. Before you shut the engine off, close the valve.
Then then next time you're going to go for a drive, just open up the valve before you start the engine and the oil under pressure will flow back into the engine and pressurize it. You'll probably have to run an extra quart or so to allow for the storage depending on the size of the tank you choose and it should take care of your problems.
Just an idea! Brian[ Parent ]
Best Regards,
troy[ Parent ]
Keep having fun out there!
