OK scroungers, I need your help. | 15 comments (15 topical, editorial)
Re: OK scroungers, I need your help. (none / 0) (#11)
by troy on Sat Jun 14th, 2003 at 09:33:35 AM MST
Actually, the engine's oil pump does replenish the pre-oiler tank.  I have a valve that I open manually, then start the engine and close the valve.  But there's a check valve that allows the now pressurized oil from the engine to refill the pre-oiler and repressurize the air.  The difficulty is that the oil absorbs the pressurized air in the tank over the span of a week or two, thus requiring a recharge from an air compressor.  Anyway, it'll be fun to build a pump from scratch, including winding the compression springs and building the integral check valves.
Best Regards,
troy
OK scroungers, I need your help. | 15 comments (15 topical, 0 editorial)
