-Andrew[ Parent ]
Thanks again,
troy[ Parent ]
Besides, I have a strong little 12v motor with a nice step down gear that I recycled from a dead mini air compressor. Make a little piston, drill and ream a little cylinder, punch out some leather "o-rings" to use for piston rings and wind a couple of compression springs to make the check valves. Cost will be minimal and it's a good learning experience.
Best regards,
http://www.autoenginelube.com/pages/903473/index.htm
My '92 Bronco with the 351W has nearly 200,000 miles on it now and it performs flawlessly. All I do is change the oil every 3k miles and do the usual maintenance such as changing the air filter, plugs, cap, rotor, etc. so I couldn't be happier. I can't say if it's because of this sytem or not, but it certainly couldn't have hurt!! Not bad for a Ford eh!!! ;-)
Good luck with your project! Brian[ Parent ]
