OK scroungers, I need your help. | 15 comments (15 topical, editorial)
Re: OK scroungers, I need your help. (none / 0) (#6)
by troy on Tue Jun 10th, 2003 at 06:19:30 PM MST
I thought about the diaphragm thing for some time and decided it would make the project just too complex.  And inner tube material gets wierd with long term contact with oil.
Besides, I have a strong little 12v motor with a nice step down gear that I recycled from a dead mini air compressor.  Make a little piston, drill and ream a little cylinder, punch out some leather "o-rings" to use for piston rings and wind a couple of compression springs to make the check valves.  Cost will be minimal and it's a good learning experience.
Best regards,
troy
Re: OK scroungers, I need your help. (none / 0) (#7)
by Brian on Tue Jun 10th, 2003 at 06:56:10 PM MST
Hey, I think it's great you make your own setup. I don't know if you're interested or not, but I use this product on my Ford and it works flawlessly. Check it out.....
http://www.autoenginelube.com/pages/903473/index.htm
My '92 Bronco with the 351W has nearly 200,000 miles on it now and it performs flawlessly. All I do is change the oil every 3k miles and do the usual maintenance such as changing the air filter, plugs, cap, rotor, etc. so I couldn't be happier. I can't say if it's because of this sytem or not, but it certainly couldn't have hurt!! Not bad for a Ford eh!!! ;-)
Good luck with your project! Brian
OK scroungers, I need your help. | 15 comments (15 topical, 0 editorial)
