The coils will be in phase when the same magnet pole is on top of each at any given time. If they are in phase then you connect start to finish for series. And start to start for parallel.
Here it looks as if they are in phase at the neutral and at the tails (parallel, start to start), but when the series connection takes place it looks like the poles are different (start to start again in series).
It doesn't look right. But if you check as described in the text you will be OK.Hugh Piggott http://www.scoraigwind.co.uk[ Parent ]
Confusing, but I think correct. To be safe, check voltage as you hook it up.
best regards,
troy[ Parent ]
Lots of fun
Ed Have Fun! Windstuff Ed[ Parent ]
