how to hook coils up in single phase | 4 comments (4 topical, editorial)
starts going to starts (none / 0) (#2)
by scoraigwind (magnet@scoraigwind.co.uk) on Mon Jun 9th, 2003 at 01:32:34 PM MST
(User Info) http://www.scoraigwind.co.uk
We need to know the layout of the magnets, but I think you are right that there is something wrong here.
The coils will be in phase when the same magnet pole is on top of each at any given time.  If they are in phase then you connect start to finish for series.  And start to start for parallel.
Here it looks as if they are in phase at the neutral and at the tails (parallel, start to start), but when the series connection takes place it looks like the poles are different (start to start again in series).
It doesn't look right.  But if you check as described in the text you will be OK.
Re: starts going to starts (none / 0) (#3)
by troy on Mon Jun 9th, 2003 at 02:17:10 PM MST
The diagram would perhaps look more familiar if the coils were installed every other one clockwise, every other one counter clockwise.  Then they can be wired in simple series fashion (start to end, start to end).  But if they are all wound clockwise and all installed clockwise, then simple series connection will lead to voltage cancellation, thus the need to hook them up in serie as: start to start, end to end, etc.
Confusing, but I think correct.  To be safe, check voltage as you hook it up.
best regards,
troy
Re: starts going to starts (none / 0) (#4)
by windstuffnow (elenz(at)windstuffnow(dot)com) on Mon Jun 9th, 2003 at 03:32:28 PM MST
  I typically wind mine clockwise then the next counterclockwise and so on.  I can see where the diagram could be a little confusing at first but in essence it is correct if your winding them all the same direction and making connections for every coil.
Lots of fun
Ed
Have Fun! Windstuff Ed
how to hook coils up in single phase | 4 comments (4 topical, 0 editorial)
