motor to generator | 5 comments (5 topical, editorial)
Re: motor to generator (none / 0) (#3)
by Smithson on Tue Jul 29th, 2003 at 07:25:25 AM MST
    Zubby:   There is another way to figure the poles.
     Frequency = nbr of poles  x   RPM/120      Smithson
Re: motor to generator (none / 0) (#4)
by zubbly on Thu Jul 31st, 2003 at 05:55:30 PM MST
(User Info) www.zubbly.com
hello Smithson, i was trying to explain to Allan how to check for number of poles in order to determine correct speed. i felt that his assumption that his motor was 8 poles was in jeopardy and did not want to see him use up many magnets to convert rotor. when name plate is damaged and winding is encapsulated, this is a good way to determine speed. your formula to determine frequency however is correct. a motor with 8 poles @ 60 cycle wood give 900 rpm at synchronous speed, and 450 rpm @ 30 cycle. i am assuming that Allan's motor is 60 cycle.
zubbly
motor to generator | 5 comments (5 topical, 0 editorial)
