Build this battery | 8 comments (8 topical, editorial)
Re: Build this battery (none / 0) (#2)
by iFred (ifred2006@yahoo.com) on Fri Jan 30th, 2004 at 09:34:21 AM MST
AHHH HA!
Galvanic currents are generated by two dissimilar metals immersed in water. If they are in close proximity to each other they will generate a voltage potential.
Water has resistance to current flow, any form of acid or chemical can either increase or decrease the electrical resistance of the water. This solution is called an electrolyte.
Maximizing the size of the plates should also increase the current flow and voltage.
Build this battery | 8 comments (8 topical, 0 editorial)
