Front Page
[Homebrewed Electricity
(wind)
(solar)
(hydro)
(steam)
(controls)
(storage)
(mechanical)
Classifieds
Site News
Everything
Newbies
[Remote Living
(housing)
(heat)
(light)
(water)
Rants & Opinion
Diaries
Our Products
Build this battery
8
comments (8 topical, editorial)
Re: Build this battery
none / 0
#3
by windstuffnow (
elenz(at)windstuffnow(dot)com
) on Fri Jan 30th, 2004 at 11:07:56 AM MST
User Info
http://www.windstuffnow.com/main
iFred,
We used to run crystal radios from a bowl of water back in the late 60's. Same method using dissimilar metals. Use larger plates and your amps will come up. If you burry 2 sheets of metal in your back yard you'll be able to charge your Ni-Cads fairly quickly as long as the ground is moist. If the power drops off simply turn the sprinkler on.
Mount a microwave transformer about 3 ft from the power utility line... tons of free energy ( don't get caught... its not legal ). String a wire to the top of one of your towers down to the ground. Connect a one wire circuit at the bottom bingo free energy... ok not really free but its free to you... the power fluctuates but it will charge batteries... also if you wind a coil around a flourescent tube and connect it to the wire you have a lighted pole.
Energy is everywhere, just need to harness it!!
Have Fun
Have Fun! Windstuff Ed
Parent
none / 0
#4
by Budgreen on Fri Jan 30th, 2004 at 11:49:38 AM MST
User Info
this will also work with RF energy from a nearby radio station, using a tuned circuit you can extract small amounts of energy through the antenna (you must be very close to the station antenna like 1/4 mile or less)
Parent
Build this battery
8
comments (8 topical, 0 editorial)
create account
How to use the board
FAQs
search the board
Google search the board
Old Otherpower Board
