Can Battery damage occur from to much voltage... | 7 comments (7 topical, editorial)
Re: Can Battery damage occur (1.00 / 1) (#2)
by eformx on Wed Oct 13th, 2004 at 08:05:23 PM MST
Do you know if there is a charge controller that will handle the voltage, is there a manufacturer that you can suggest or is there a kit/plans so I could piece together a charge controller?
I suppose if it had the ability to transfer the excess to a 12 volt heater that  would also be a benefit.
Hmmm...
Rob
Re: Can Battery damage occur (3.00 / 0) (#5)
by erne on Thu Oct 14th, 2004 at 07:10:49 AM MST
agm batt??? isn't that a sealed batt. if so how do you add water?? don't they daMAGE EASIER FROM OVERCHARGE OR EQUALIZING??  erne
Re: Can Battery damage occur (3.00 / 0) (#6)
by eformx on Fri Oct 15th, 2004 at 09:07:07 PM MST
Text from a site...AGM, Absorbed Glass Mat, AGM's will generally go for 5 to 8 years. A newer type of sealed battery uses "Absorbed Glass Mats", or AGM between the plates. This is a very fine fiber Boron-Silicate glass mat. These type of batteries have all the advantages of gelled, but can take much more abuse. These are also called "starved electrolyte", as the mat is about 95% saturated rather than fully soaked. That also means that they will not leak acid even if broken.
AGM batteries have several advantages over both gelled and flooded, at about the same cost as gelled:
Since all the electrolyte (acid) is contained in the glass mats, they cannot spill, even if broken. This also means that since they are non-hazardous, the shipping costs are lower. In addition, since there is no liquid to freeze and expand, they are practically immune from freezing damage.
Nearly all AGM batteries are "recombinant" - what that means is that the Oxygen and Hydrogen recombine INSIDE the battery. These use gas phase transfer of oxygen to the negative plates to recombine them back into water while charging and prevent the loss of water through electrolysis. The recombining is typically 99+% efficient, so almost no water is lost.
The charging voltages are about the same as for any standard battery - no need for any special adjustments or problems with incompatible chargers or charge controls. And, since the internal resistance is extremely low, there is almost no heating of the battery even under heavy charge and discharge currents. These batteries have no charge or discharge current limits for all practical purposes - you would exceed the wire amperage capacity long before you reach the danger point. Note that we do not recommend "super charging" them, but it can be done if you really need to.
AGM's have a very low self-discharge - from 1% to 3% per month is usual. This means that they can sit in storage for much longer periods without charging than standard batteries. The batteries can be almost fully recharged (95% or better) even after 30 days of being totally discharged.
AGM's do not have any liquid to spill, and even under severe overcharge conditions hydrogen emission is far below the 4% max specified for aircraft and enclosed spaces. The plates in AGM's are tightly packed and rigidly mounted, and will withstand shock and vibration better than any standard battery.
Even with all the advantages listed above, there is still a place for the standard flooded deep cycle battery. AGM's will cost 2 to 3 times as much as flooded batteries of the same capacity. In many installations, where the batteries are set in an area where you don't have to worry about fumes or leakage, a standard or industrial deep cycle is a better economic choice. AGM batteries main advantages are no maintenance, completely sealed against fumes, Hydrogen, or leakage, non-spilling even if they are broken, and can survive most freezes. Not everyone needs these features.
Hope this helps.
Rob
Can Battery damage occur from to much voltage... | 7 comments (7 topical, 0 editorial)
