Electronic Stirling | 20 comments (20 topical, editorial)
Re: Electronic Stirling (3.00 / 0) (#19)
by iFred (ifred2006@yahoo.com) on Mon Oct 18th, 2004 at 01:25:11 PM MST
Version 1067... ummmm... NEXT!
JW.. Check out the above links.. You can make them any size or dimension. THey do not seem that complicated to build either. I think it is do-able.
Re: Electronic Stirling (3.00 / 0) (#20)
by joedupont (joedupont@juno.com) on Thu Feb 15th, 2007 at 03:27:06 PM MST
WHY NOT USE THE PELTIER UNITS TO TAKE WASTE HEAT FROM THE STIRLING ENGINE AND RUN A FAN TO COOL THE STIRLING ENGINE AND ITS SELF . IN THAT WAY ONE WOULD HAVE TO PICK UP
EFFICIENCY.. IF THE PELTIERS COULD HELP RUN THE DISPLACER WITHOUT SEALS ALL THE BETTER. SUCH A HYPRID  STIRLING ENGINE MIGHT BE WORTH LOOKING INTO..
HAS ANYONE SEEN THE ROTARY DISPLACERS  .. NO UP AND DOWN.. JUST A ROTARY DISPLACER SWEEPING THE AIR ON THE OPEN SIDE.
MAYBE PELTIERS COULD OPERATE ELECTRONIC STIRRERS..INSTEAD OF DISPLACER.
IF THE MOTORS ARE ALTERNATING STIRRING THE  AIR IN THE  THE HOT AND COLD SECTION OF THE DISPLACERS THEN YOU ARE NOT MOVING A MASSIVE UNIT.  JUST A THOUGHT.
THE ELECTRONICS YOU GUYS SEEM TO HAVE A HANDLE ON.
PERHAPS TWO LOOPS WITH  A SPACE IN COMMON.   HUMM.
Our mission is to keep ourselves entertained with knowledge and learning through creativity. As long as we can create as long as we breath with out the governm
Electronic Stirling | 20 comments (20 topical, 0 editorial)
