1 coil, 1 magnet, 1 AC wave | 16 comments (16 topical)
Re: 1 coil, 1 magnet, 1 AC wave (3.00 / 0) (#3)
by wooferhound on Sat Oct 02, 2004 at 08:42:01 AM MST
Can't you trim down the file size on those pictures ?
I'm not sure where your Zero Volt line is on your scope, but
As I understand it . . .
Arranging the magnets North-South-North-South-North-South
is doubling your voltage. The norths passing the coil pull the voltage
to the Plus side of the zero line, then the Souths passing the coil pull
the voltage to the Negative side of the zero line, the combination is
double the AC voltage.
I would be courious to see the scopes waveform using only 2 magnets
and passing the coil as North-South ?
)}=- W o o f -={(
Re: 1 coil, 1 magnet, 1 AC wave (3.00 / 0) (#5)
by troy on Sat Oct 02, 2004 at 10:11:23 AM MST
The file size for the photos was reduced by 75% so you don't have to scroll to read the text.  I also added a warning about the long post and photos for those that have slow connections. Sorry for the inconvenience.
The results of two magnets passing one coil one time would depend on the magnet to magnet spacing. But that was not the bone of contention in the original discussion.  There are lots of fun variations you can try with coil leg width, inter coil spacing, coil hole size compared to magnet size, etc etc etc ad infinitum.  But I wanted to bring clarity to the most fundamental issue of what happens when one magnet passes one coil one time. If we can't agree on that we're beat.
Good luck and have fun!
troy
