Wind power air compressor? | 26 comments (26 topical, 0 editorial)
Re: Wind power air compressor? (3.00 / 0) (#11)
by kays2002 on Sat Apr 1st, 2006 at 03:52:51 AM MST
Gas turbines use compressors to mix compressed air with the fuel to burn. By replaceing the coventional wind turbine with  a micro hydro turbine, the compressed air can be used without the need of storing it. Can Turbo chargers be used to get compresed air?
Re: Wind power air compressor? (3.00 / 0) (#15)
by spinningmagnets (velmis1450bc(at)aol(dot)com) on Thu Sep 13th, 2007 at 08:13:42 PM MST
I always encourage "thinking outside the box", and I don't want to sound as though I am discourageing any experimentation, but..
A turbocharger would have to spin many thousands of RPM's to get any appreciable compression. I doubt that this would prove to be a useful route (and I'm a fan of turbo's).
I recall an adapter that allowed a motorcycle enthusiast to use the electric starter to spin the engine and get air pressure through the spark plug hole of one of the cylinders to fill an air mattress when camping, so this line of logic is "do-able".
I also recall that the firing order of a Ford 302 allowed one bank to operate as a smooth firing 4-cylinder, while the other bank of the engine functioned as a 4-cyl air compressor.
http://www.southern-tool.com/store/grimm-schmidt_gas_compressors.html http://www.ytmag.com/toolt/messages/143175.html
There is also a kit that involves a custom cam, and several other adapters that converted a VW air-cooled 4-cylinder bug engine so that two cylinders functioned as an engine, and two of the cylinders acted as an air compressor.
http://www.angelfire.com/biz/dunnright/DR3.html
I am a fan of efficiency, but efficiency is a relative term, in that, if the wind/water is free, then, if an IN-efficient device made from free junk can perform a job that you need...start out in-efficient and work your way up as time and money allow.
"If at first you don't succeed...you probably shouldn't try skydiving."
-Henry Youngman.
