Wind power air compressor? | 26 comments (26 topical, editorial)
Re: Wind power air compressor? (3.00 / 0) (#13)
by ghurd on Thu Sep 13th, 2007 at 12:52:12 PM MST
The vast majority use a 3 or 4 cyl diesel compressor and 1000 to 3600 gallon air tanks.
They use it like anybody uses air, mostly tools.
The only 'unusual' item I can think of is the air powered well pump. Someone living alone may have a 8HP Gasoline Honda compressor and 500 gallon air tank, primarily for the well pump.
Lancaster Amish tend to be a little different than most other areas. I believe you will be disappointed if you only travel to Lancaster.  You may find more of what you are looking for in Western Pennsylvania, Ohio, or Indiana. Not sure what you expect to see.
I am in NE Ohio.
Re: Wind power air compressor? (3.00 / 0) (#14)
by ghurd on Thu Sep 13th, 2007 at 03:11:57 PM MST
Also, K3CZ has not done anything on this board for almost a year, and this is a 3 year old story.
It may help if someone with the information you seek has your contact information.
Wind power air compressor? | 26 comments (26 topical, 0 editorial)
