Cheap Solar panel experience | 12 comments (12 topical)
Re: Cheap Solar panel experience (3.00 / 0) (#5)
by E man on Tue Oct 05, 2004 at 12:18:25 AM MST
Just a thought, but you may want to check the output current of each panel separately.  You may have only one bad egg in the bunch that's bringing the other down when you wire them in parallel.
You mentioned a possible "manufacturing defect" could be the cause of the current drop...I was shopping for a cheap 50 watt panel a month ago, and got an earful of good advice from a local PV distributor.  One of the interesting things I learned was that  the major cause of panel [power] degradation comes from the middle sandwich layer between the glass and silicon; it's termed the encapsulent and acts as a clear cushioning layer.  Ethylene vinyl acetate I think is the stuff.  Apparently it degrades slowly under UV exposure and pretty much determines the productive lifespan of a solar panel.
E-man
