refrigeration ? | 12 comments (12 topical, editorial)
Re: refrigeration ? (3.00 / 0) (#10)
by nack on Thu Nov 18th, 2004 at 07:01:15 PM MST
Why drill?  A spring clip will hold the sensor-bulb just fine - hell, a lump of sticky tar will hold it OK.  I would even go so far as to guess that a modern refrigeration device probably has a bunch of insulation around the cold box, you could just wedge the bulb under the insulation.
refrigeration ? | 12 comments (12 topical, 0 editorial)
