I'll be experimenting with low power fridges also soon myself. My plan is to run cold water from the well through a heat exchanger to cool the water in a barrel which the coils will sit in. And I plan to also burry the barrel to get ground temps when the well hasn't been running. Part of my preheater for the hot water tank and solar system. I don't expect to do much for heating water this way and a 55gal barrel, but it should keep those coils cold!
If you try water cooling, remeber they still use lead in some solders, maybe the coils, so keep it seperate.. nothing to lose
Volvo Farmer
May you always have success in your quest to irritate those who you despise. -Ben Goode [ Parent ]
SDO-aka-Todd--- Super Dave Osbourne, Man of a Million Shunts "Not that I expect the current administration to do anything about it."[ Parent ]
