google came up with a few answers about china's fuel demands.. this winter will be cold in Bejing for many ppl due to a shortfall in coal production... petrochemical usage is set to increase substantially (maybe as a result???)
see; http://www.peakoil.com
The future of oil products as we know it is limited... peak oil is set to happen soon... 2005, 2007, 2010... odds neone??? paul
p.s. what will happen to plastics production when 'the-oil-runs-out'?
Good point. You can also toss in drugs that are based on oil.
It just seems that burning up oil to get around is a bit like burning your furniture to keep warm because your too lazy to cut wood. Many things can be used for motive power but oil is so useful for other things it should not be consumed for heat and transportation.
Just the view from here.
T
Uknow I agree with you on many points. Thinking about the Hydrogen economy, I often wonder if the trend that which we consume oil currently, will be any example of our stratigy with water in the same respect. What I mean is, electrolisis with pure water it probably best, since salt water will emit tons of clorine on the Oxy side. So theres another energy sink besides compression of gas and liquifaction(supercooling), as de-salination energy needs would accumulate cumulaive on the energy balence thats needed to produce usable hydrogen, regardless of the energy sources used to produce it. Nevertheless the balence is out of wack in this regard, since hydrogen is only an energy carrier and it takes more energy to produce a given quantity, then is released at an end use point, such as a fuel cell. Considering generally fuel cells are only 60% efficient, then 40% of the original hydrogen used is lost to heat, as in-efficiency. Even though water is in fact recovered as a result of the fuel cell process, 40% of the original Hydrogen consumed from electrolisis is lost thru heat of just the fuelcell process. This means water is infact being consumed irreversably if thru only the fuelcell, let alone liquifaction losses and distribution losses, and end use losses.
By the way, I have heard any plastic that can be made from oil can be made fron corn. Often bio-mass can replace the complex organic materials that oil produces for us now. But conservation is alway censible. Thinking about this, it remindes me that sponges and other rare marine oganisms living in the Worlds Oceans, exist because of a delicate balence of water volume, thermodynamically and salination wise this is an important nursery of life and potental cancer curing drugs extracts, that could be derived from sea life. Let alone preventing drought in protected rain forest areas. We can live without oil, but can we live without water? Just an opinion, directed at generallity.
JW[ Parent ]
Except for certain regions of the world, I don't think salt water will be needed. An acre-inch of water is equal to 28,359 gallons of water. Where I live we get 250 inces of snow (25 inches water equivalent) per year plus rain. Lets say 30 inches of rain equivalent per year. So, that's 850,770 gallons of water per acre. I own 60 acres, so I'm entitled to process up to 51 million gallons of water per year into hydrogen. The problem, of course, is that most of the water runs off. And, since the water is returned back to the environment when the hydrogen is burned, it becomes a closed cycle. The hydrogen used in California, for instance, may fall as snow in the mountains and be used again by Californians.GeoM[ Parent ]
Spellchecker seems out of order!-- Always find the typos after posting![ Parent ]
A country doesn't have to be democratic to be technologically advanced. Take a hard look at Germany before WW2. They had potential developements in place that would have greatly altered the outcome of the war. Basically, Hilter wasn't interested until it was too late. Hilter started the war and he lost it too, due to his attitudes. He was also looking for raw materials, namely oil.GeoM[ Parent ]
