Basically my reasons for using this rather than a cheap digital meter are the same as listed here:
http://www.homepower.com/files/bat-o-meter.pdf
Essentially, you don't have to keep replacing 9V batteries in this one, and you can tell from the other side of the room if your battery is getting low (without having to refer to a chart of voltage levels). Less is more! ;-)
BTH[ Parent ]
