How to build a cheap LED voltmeter | 17 comments (17 topical, editorial)
Re: How to build a cheap LED voltmeter (3.00 / 0) (#2)
by Nando (nando37-at-tx-dot-rr-dot-com Correct theanti-spam) on Sun Dec 19th, 2004 at 08:32:40 PM MST
BT :
I have circuits that could be built for that purpose, please connect with me directly.
Using the LM3914 and some ancillary parts
nando37-at-comcast-dot-net
Regards
Nando
Re: How to build a cheap LED voltmeter (3.00 / 0) (#3)
by BT Humble (bt_humble@bigpond.com) on Sun Dec 19th, 2004 at 08:48:29 PM MST
BT :
Thanks Nando, I've already looked at those (in fact, the $14.95 kit I mentioned is based on that IC).  Unfortunately the best price I can get for LM3914 chips is $4.45 each (in quantities of 25 or more), whereas I can build this entire circuit (including the PCB) for $4.60
Additionally, this cicuit only draws 30mA, while the LM3914 circuits that I've seen (at least 3 variations available on the web) are around double that.
BTH
Re: How to build a cheap LED voltmeter (3.00 / 0) (#6)
by jimjjnn (jimjjnn at yahoo dot com) on Mon Dec 20th, 2004 at 06:34:26 AM MST
The 3914 circuit is a great one. Radio Shack also has a circuits book showing various configurations using the 3914. It may even simplify the circuit for you and will use fewer parts( I think)
Jim Denver,CO
How to build a cheap LED voltmeter | 17 comments (17 topical, 0 editorial)
