How to build a cheap LED voltmeter | 17 comments (17 topical, editorial)
Re: How to build a cheap LED voltmeter (3.00 / 0) (#9)
by BT Humble (bt_humble@bigpond.com) on Mon Dec 20th, 2004 at 07:28:32 PM MST
You my want to try replacing the 1K resistor on the led that indicates 13.5 or so volts with a reed relay with 1k coil resistants.
Then you would have a shunt type regulator you could turn on a dump load
Or disconnect the panels to keep the battery from over charging.
It wouldn't add that much to the cost and would protect a more costly battery. Just a thought.
Good idea, thanks.
Also, I think I've messed up a bit there and built a circuit that will fry trimpots if they're incorrectly adjusted - I think I should be using a lower-voltage zener with a 1k resistor between it and the trimpot. (ie. zener->resistor->connection to the transistor bases->trimpot).
I'll post an updated diagram once I've sorted that problem.
BTH
Re: How to build a cheap LED voltmeter (3.00 / 0) (#13)
by Ungrounded Lightning Rod on Wed Dec 22nd, 2004 at 04:32:48 PM MST
How about, insteading of grounding the tap of the trimpot and hooking the diodes to the top, grounding the bottom of the trimpot and hooking the diodes to the tap?
Re: How to build a cheap LED voltmeter (3.00 / 0) (#15)
by BT Humble (bt_humble@bigpond.com) on Tue Jan 4th, 2005 at 02:35:35 PM MST
That would probably work too, but I gave this a try yesterday and now the whole thing works pretty much the way I intended it to:
If you want to increase the voltage spacing between the LEDs you can add an extra diode in series (as I've done with Q1).
I've revised the PCB layout a bit to accomodate the changes, and it now measures 100x25mm (4x1").  I'll post the artwork here if anyone is interested.
BTH
How to build a cheap LED voltmeter | 17 comments (17 topical, 0 editorial)
