Ibedonc : When You say " + - 80vdc to get 120ac " Are you talking a split rail votage here ?( a positive reference to ground and a negative reference to the same ground of 80vdc each ? )
Idealy I need an inverter that can operate on an input of between 105vdc and 160vdc. I guess this would be the normal operational levels between a 120v bank of standard deep cycle lead acid batteries ?
I have printed off all of your work that you have published... as soon as I get the time, I'm going to print off the chip specs as well. I have to say... right now I don't understand exactly what's going on within the circuit you have :( But I hope too soon : ) It sounds so promising, yet alot more simple then a CPU based setup.
Do you belive your circuitry would be adaptable to my situation where I need aprx. 105vdc to 160vdc input and 120vac output ? would your circuit drive a step up transformer so that 120vac RMS would be availalbe at the low end of 105vdc input, and in about 5 to 8 kw in size ?
John II
