Static Electricity Wind Generator | 19 comments (19 topical, editorial)
Re: Static Electricity Wind Generator (none / 0) (#2)
by franknbuger on Fri Apr 2nd, 2004 at 08:10:31 AM MST
   Hello!
  People have been using static wind charging for many years.Be careful the charge can get quite high.Below is a link to: "Capicitive Battery Charger".The more wire the more voltage.Let me know if this helps.As I always say please advise.
                                                Frankenbuger
    http://www.fortunecity.com/greenfield/bp/16/capcharg.html
Re: Static Electricity Wind Generator (none / 0) (#3)
by Electric Ed on Fri Apr 2nd, 2004 at 02:58:46 PM MST
My firewall (Zonealarm) doesn't like that site. Approach with caution.
Electric Ed
Re: Static Electricity Wind Generator (none / 0) (#4)
by kell on Fri Apr 2nd, 2004 at 05:31:15 PM MST
The diagram doesn't quite agree with the text.  What's the right way to do it?
Re: Static Electricity Wind Generator (none / 0) (#5)
by DakotaSIG on Fri Apr 2nd, 2004 at 08:47:24 PM MST
Yeah, I don't see how that would work as drawn either.
I haven't built one of these, but the way I understand them to work is to connect one side of the capacitor to the charge collector wire and the other side of the capacitor goes to ground. The spark plug, coil, and battery are all hooked in series and then placed in parallel with the capacitor. The spark plug gap is adjusted to limit the voltage on the capacitor so it doesn't break down. When the spark plug breaks down, the charge in the capacitor flows through the arc into the coil. The coil is only acting as an inductor not a transformer. The coil provides a place for the current pulse to go until it can be absorbed by the battery. No connection is made to the coil secondary.
Hopefully, somebody here has built one of these and can explain it better.
BTW, I think this was originally a Tesla idea (radiant energy), so look for a reference to Tesla patents.
Re: Static Electricity Wind Generator (none / 0) (#7)
by HareBrained on Sat Apr 3rd, 2004 at 04:10:35 PM MST
Thanks for the link, Frankenbuger, it looks interesting.
I had something in mind like the circuit on that page for collecting
the charge, but I guess I don't understand the effect that's being used
to charge up the long wire.  Is it coming from EM waves, using the wire
sort of like an antenna?
What I had in mind would actually use the wind to do some work, separating
oppositely charged ions from one another.  It wouldn't be free energy or
perpetual motion, just a new way to use the wind with a solid-state type
generator machine.
What I don't know is how many volts a segment of PVC pipe would build
up in the wind, or how many nanoamps you could expect to get from it.
I assume you would take it through an inductor of some kind in a buck-boost
type arrangment to collect charge in a capacitor and do some battery
charging.
Re: Static Electricity Wind Generator (none / 0) (#9)
by DakotaSIG on Sat Apr 3rd, 2004 at 09:30:14 PM MST
When the wind blows against trees, buildings, etc. it (the wind) becomes charged. Air rubbing against something will collect charge in the same way a rabbit fur rubbing on plastic collects charge. Air is an insulator just like pvc pipe, so the charged air molecules don't have any way to conduct their charge to ground. The static charger wire collects this charge when the wind blows the charged molecules against it. That's how the wire becomes charged. Hope this helps. :)
Re: Static Electricity Wind Generator (none / 0) (#14)
by HareBrained on Sun Apr 4th, 2004 at 11:02:50 AM MST
Right, that's how I understand static electricity works, but the two
pages seemed to be talking about "radiant energy" which is something
else.
I imagine you could wind a piece of bare wire around the PVC pipe, sort of
in a wide spiral with lots of room between the turns, as a way to collect
the charge from the surface of the pipe.  I am guessing that these "radiant
energy" collectors being described are collecting the static charge from
the insulation, but they require the charge to pass through
the insulation which might be reducing performance.  I would guess that
the strongest static charge would really be on the surface of the insulator
so it would be best to collect it from there.  Also, the use of a big
(4" diameter or so) pipe would give the wind lots of surface area to work
on.
Perhaps, though, the bare wire on the outside would interfere with the static
collection by returning some charge to the air.  So, maybe you'd need to
coat it with an insulator or bury it slightly in the PVC by using some
glue to dissolve the surface just below the wire.
Anyway, just more random thoughts... if I get some time it'd be fun to try
to build one of these.
Static Electricity Wind Generator | 19 comments (19 topical, 0 editorial)
