Static Electricity Wind Generator | 19 comments (19 topical, editorial)
Re: Static Electricity Wind Generator (none / 0) (#9)
by DakotaSIG on Sat Apr 3rd, 2004 at 09:30:14 PM MST
When the wind blows against trees, buildings, etc. it (the wind) becomes charged. Air rubbing against something will collect charge in the same way a rabbit fur rubbing on plastic collects charge. Air is an insulator just like pvc pipe, so the charged air molecules don't have any way to conduct their charge to ground. The static charger wire collects this charge when the wind blows the charged molecules against it. That's how the wire becomes charged. Hope this helps. :)
Re: Static Electricity Wind Generator (none / 0) (#14)
by HareBrained on Sun Apr 4th, 2004 at 11:02:50 AM MST
Right, that's how I understand static electricity works, but the two
pages seemed to be talking about "radiant energy" which is something
else.
I imagine you could wind a piece of bare wire around the PVC pipe, sort of
in a wide spiral with lots of room between the turns, as a way to collect
the charge from the surface of the pipe.  I am guessing that these "radiant
energy" collectors being described are collecting the static charge from
the insulation, but they require the charge to pass through
the insulation which might be reducing performance.  I would guess that
the strongest static charge would really be on the surface of the insulator
so it would be best to collect it from there.  Also, the use of a big
(4" diameter or so) pipe would give the wind lots of surface area to work
on.
Perhaps, though, the bare wire on the outside would interfere with the static
collection by returning some charge to the air.  So, maybe you'd need to
coat it with an insulator or bury it slightly in the PVC by using some
glue to dissolve the surface just below the wire.
Anyway, just more random thoughts... if I get some time it'd be fun to try
to build one of these.
Static Electricity Wind Generator | 19 comments (19 topical, 0 editorial)
