wind charge controller | 6 comments (6 topical, 0 editorial)
Re: wind charge controller (3.00 / 0) (#6)
by suns10 on Sat Oct 16th, 2004 at 08:49:56 PM MST
Thanks for the reply..
I am new to this and no expert but I think that is true as long as the dump load is large enough to dump the same or more power than the wind generator and solar panel are delivering to the batteries.  Once the lower limit on the contoller is reached due to the batteries discharging to 13 volts the dump load is switched off and batteries charge again.
I will be putting a 200 watt windmill for battery charging in at my very remote cabin and I think an item like this will work well in freezing tempuratures as the cabin is in northern Minnesota and not heated in the winter unless occupied.  Other regulators have digital displays and other electronics and I worry they may fail in -20 degrees F.
I'm not sure what size of dump load to put in place however.  I think a 12V 500 watt light or heater load should be OK. I want to get it right because I can be away for weeks at a time.
Thank you,
