Homemade Solar Panels | 12 comments (12 topical, editorial)
Drilling plastics (3.00 / 0) (#3)
by wdyasq on Wed Jan 5th, 2005 at 07:26:12 AM MST
I'm a fan of using tempered glass.  It is inexpensive and has proven record of transparency and durability.
However, if one cares to use Acrylics or Polycarbonates they will be well advised to learn the proper way to sharpen drill bits where they will not break the material.  After driling or cutting all edges and holes need to be beveled to remove the stress risers created in the cutting process.
Re: Drilling plastics (3.00 / 0) (#6)
by Tom in NH (tom@altenergyweb.com) on Wed Jan 5th, 2005 at 09:03:48 PM MST
(User Info) http://altenergyweb.com
Tempered glass is a fine covering. It is a little on the expensive side, but good. Regarding plexiglas and holes drilled in it near the edges, I found I had to drill a hole slightly oversized and then be extremely careful not to tighten the screw down too tight. As far as drilling goes, it's not a problem if you don't push too hard on the drill bit and you have a solid surface under the plexiglas. Any flex at all will cause problems. Can you tell me more about proper sharpening of drill bits for plastics? --Tom
Re: Drilling plastics (3.00 / 0) (#7)
by ixtow on Wed May 3rd, 2006 at 04:16:16 PM MST
I'm having trouble finding an apple to apples comparison of the polymers to tempered glass.
Plexiglass doesn't last long enough.  I'm trying to pick Lexan or Tempered glass.  Can't get straight apples to apples comparisons of price.
Homemade Solar Panels | 12 comments (12 topical, 0 editorial)
