Monitoring Amps using Hall Effect Sensor | 26 comments (26 topical, 0 editorial)
Re: Monitoring Amps using Hall Effect Sensor (3.00 / 0) (#22)
by RobD on Wed Oct 26th, 2005 at 07:03:48 AM MST
I use the Allegro ratiometric hall chips.
Here's a link:
http://www.allegromicro.com/techpub2/techpub2.htm#B
Check the 27702 notes.
RobD
Re: Monitoring Amps using Hall Effect Sensor (3.00 / 0) (#23)
by tecker on Wed Oct 26th, 2005 at 03:53:08 PM MST
Cool site
Re: Monitoring Amps using Hall Effect Sensor (3.00 / 0) (#24)
by geoffd on Thu Oct 27th, 2005 at 12:34:32 PM MST
Hi Rob,
thanks for that pointer, it is a very interesting document.  I need to digest it and work out if what I am doing is feasible.  Part of the problem is the dynaic range of what I want to measure.  Most of the time it will be perhaps 5 - 10 amp, then when the heavy loads are on it might be 100 - 12- amps , and when I switch in my arc welder 200 - 300 amps :)  Don't do that often!  But good info thanks.
Geoff
Re: Monitoring Amps using Hall Effect Sensor (3.00 / 0) (#26)
by RobD on Fri Oct 28th, 2005 at 06:23:51 AM MST
You can bias the coil to to increase the range the hall senses.
Allegro is great about sending out samples. I have an electronics business but I think they are even pretty good to hobbiests.
They also sell a current sensor for high current apps.I'm away so I don't have the number on hand but if you do a search on thier site i should come up.
Another chip you might want to check out is the Zetex ZXCT1009. This is a current sensor. I use it for low to medium current sensing in SMPS circuits but it should work in your app. Mouser sell them at low cost.
