new jennys from italy 500 2,4 m e 3,6 m | 8 comments (8 topical, editorial)
Re: new jennys from italy 500 2,4 m e 3,6 m (3.00 / 0) (#3)
by richhagen (richhagen (a t) Juno.com) on Tue Oct 25th, 2005 at 12:51:41 AM MST
Wow, beautiful country, and beautiful machines.  You must be proud.  I am envious.
I was looking at the mounting of the rectifiers and wondering if the heat sinking is sufficient.  I took what I thought was a pretty large aluminum heat sink (about 12.5 by 26 centimeters about a centimeter thick base with about 3cm fins on that) out by the Dan's in the spring and DanB told me that it would be insufficient for a 12V roughly 3meter machine, but maybe ok for a 48V machine because the amps are so much less.  I can't tell for sure, but it looks like your rectifiers are mounted on a thin aluminum box and I'm wondering if that will be sufficient in windy weather.
Again, They look great!  Rich Hagen
Re: new jennys from italy 500 2,4 m e 3,6 m (3.00 / 0) (#4)
by Flux on Tue Oct 25th, 2005 at 01:41:33 AM MST
Superb machines and photographs,I am sure you must be really pleased with them.
I am pleased that I was able to help.
I am sure the rectifier heat sink will be adequate for 48v, especially up there in the wind.  The 12v case is a lot worse.
Look forward to hearing how they perform.
Re: new jennys from italy 500 2,4 m e 3,6 m (3.00 / 0) (#5)
by steeolico on Tue Oct 25th, 2005 at 11:46:05 AM MST
Excuse me but I have forgotten to say that the system is to 24v.
The box èeffettivamente of thin aluminum but from the photo he doesn't succeed in seeing that I have positioned others two angular thick in aluminum on the front of the scatrola together to a big squanderer for CPU.
Thank
Re: new jennys from italy 500 2,4 m e 3,6 m (3.00 / 0) (#6)
by steeolico on Tue Oct 25th, 2005 at 11:59:13 AM MST
I forgot to say that the jenny I have seen to produce woodpeckers of power of around 340W with gusts of wind (therefore the car doesn't seem to go to stalemate) but probably the strong wind still has to arrive....
The external temperature is still of around 16-18 degrees during the day.
Re: new jennys from italy 500 2,4 m e 3,6 m (3.00 / 0) (#7)
by Flux on Tue Oct 25th, 2005 at 12:28:38 PM MST
If you have thick aluminium angle under the fixing points of the bridges I think it will be ok even for 24v. you should get a lot of cooling directly to the stator mounting frame.
That is a nice output in gusts, it should go well in stronger winds.
new jennys from italy 500 2,4 m e 3,6 m | 8 comments (8 topical, 0 editorial)
