wind flex on bigger props help | 25 comments (25 topical)
Re: wind flex on bigger props help (3.00 / 0) (#10)
by adelaide on Sat Oct 29, 2005 at 11:58:52 PM MST
hi just put on lighter tail (blue 1)and seeing if still wobbles when wind picks up ,so far looks better exept pole needs more gress to turn better now.i have a suport simular to that at front is thin pole out hub aria to 3 thin ropes which goes to all blades /tringal ,helped ,dident want to lose lo speed preformanc on this 1 with extra blades but good idear if i had to many rpm/more tip loses and at gess is eqivlent to wider cord ?slower more talk. my e mail is aaron32gtr@hotmail.com (have webcam on pole if any 1 wants to see add me on msn aaron32gtr) ,for the fellow ozzze?tryed ur email dident work? and yes they are close but work well and i like to experament/compare wind ushaly hits right way so no overlap 90% time(black triangle heats air with pespe/wood/car vent fan/drill on thread for traker($30 to make ) enginer freind and me  estamates 2000w of hear /
Re: wind flex on bigger props help (3.00 / 0) (#13)
by IntegEner on Sun Oct 30, 2005 at 08:04:07 AM MST
"i have a suport simular to that at front is thin pole out hub aria to 3 thin ropes which goes to all blades /tringal ,helped ,dident want to lose lo (wind?) speed preformanc on this 1 with extra blades but good idear if i had to many rpm/more tip loses and at gess is eqivlent to wider cord ?slower more talk. my e mail is aaron32gtr@hotmail.com "
Oh, yes, I see the 3 thin ropes now that I look closer at the pictures. I give you credit. Adding blades behind other blades can actually help performance because the apparent wind the blades see when moving faster than the wind comes from the side and not so much the front. Look at www.tlgwindpower.com in Kansas of the States for a success story on using very thin aluminum blades. Send me updates on your work or start a website of your own. Contact info is on the lower left corner of my website.
Knucks
