My VAWT is almost complete! Check it out! | 18 comments (18 topical)
Re: My VAWT is almost complete! Check it out! (3.00 / 0) (#17)
by dinges on Wed Oct 26, 2005 at 09:56:05 PM MST
Hello,
Very nice design, excellent video!
One question: how do you make the 3D drawings? I'm a mech.eng. and pretty good with Autocad, but this seems made with other software. Which?
I'm finishing my (little) generator at the moment (casting the stator and rotors) and am thinking about the propellor. Then I noticed your design, plus advantages (no yawing, furling). I won't get away with placing a conventional windmill, but this VAWT might be possible to get away with. Funny eh, it doesn't look like a windmill to most people, so it isn't one as they're concerned. Rationality...
This made me think: how to make the blades. I used to build & fly model aircraft in my younger years, and I don't look forward to conventional 'rib' construction. Then it occurred to me: my father used to make wings of styrofoam, cut with a 'hot saw' (resistance wire that gets hot due to current). Very quick (once you get the feel for it), easy (only need 2 jigs to guide the saw). The foam kernel was covered by balsawood, this made a VERY strong sandwich construction. It will also be easy to nicely finish it.
Anyone use this method before for making (VAWT) windmill blades?
Good luck & keep us informed
(I will ASAP make a diary of my current construction project. Progress is however very slow (but surely)).
Peter,
The Netherlands.
Re: My VAWT is almost complete! Check it out! (3.00 / 0) (#18)
by shockwind on Sat Nov 19, 2005 at 04:31:14 AM MST
Hi Peter thanks for the comments. I am using a program called autodesk inventor for the drawings, they are the same company that makes autocad, so if you have some autocad knowledge, you will find inventor, quite simple to use.
I am currently looking into other ways of making the blades as well, I have though of styrofoam, however, I have not tried that method yet. Let us know how it works for you.
I am currently getting prepared to build a CNC Router to do my carving, I assume I would also be able to use it to cut styrofoam as well. Can't wait to get it built!
Thanks,
Steve
"Any intelligent fool can make things bigger, more complex and more violent. It takes a touch of genius-and a lot of courage to move in the opposite direction
