3-phase vs. single-phase alternator | 23 comments (23 topical, editorial)
Re: 3-phase vs. single-phase alternator (3.00 / 0) (#4)
by force9BOAT (rob@atm-international.com) on Tue Nov 22nd, 2005 at 06:19:07 PM MST
(User Info) http://www.atm-international.com
Thank you Dan,
I understand much better now.
Rob
Re: 3-phase vs. single-phase alternator (3.00 / 0) (#5)
by willib (willibur at comcast dot net) on Tue Nov 22nd, 2005 at 08:50:55 PM MST
this is a another three phase graph
Carpe Ventum (seize the wind)
Re: 3-phase vs. single-phase alternator (3.00 / 0) (#8)
by hpysheep on Thu Nov 24th, 2005 at 09:32:17 AM MST
Hi Rob,
Your question of 3 phase vs single phase power production is quite interesting when you refer to the prairie turbine site.  Prairie turbine is claiming to make 5500 watts of single phase power using a Nord 7.5hp 3 phase induction motor.  They claim to use one phase for voltage regulation, and one phase to generate electricity.....Up until I read that part, I was quite interested in Prairie Turbine's goal of creating a low cost, anyone can build, simple turbine.
If you look at their site, you see the reason they use a three phase rather than single phase motor is because it was readily available surplus from an industrial crane.
However, as they can only use one of the 3 phases to cogenerate power at a single phase household, they will only be able to extract about 2.5 hp which equates to about 1.7kw rather than the 5.5kw they claim in their breezy 5.5 ad.
If someone can correct me if my conclusions above are wrong, I would appreciate it.  Otherwise, Prairie Turbine should be looked at as another 'snake oil' sales site.
Gary
Re: 3-phase vs. single-phase alternator (3.00 / 0) (#9)
by Goose (dennishusman-at-yahoo-dot-com) on Thu Nov 24th, 2005 at 07:33:00 PM MST
((This makes me believe that the Breezy 5.5 should be renamed as the Breezy 1.7 as unless I am confused, 1.7kw is all you are going to get out of only one winding of a 7.5hp 3 phase motor.))
I haven't bought their plans yet, but from what I can tell you are using 2 phases.  If you stop and think about it,  220vac is using 2 phases(2 sets of windings).  Don't know what they mean by the 3rd phase is just voltage regulation.  I would guess it is something like making a phase converter, where you just energize the 3rd phase with caps.
Goose
Re: 3-phase vs. single-phase alternator (3.00 / 0) (#10)
by tdmack (timATprairieturbinesDOTcom) on Fri Nov 25th, 2005 at 12:58:51 PM MST
(User Info) http://www.prairieturbines.com
Gary, first of all, thanks for your order.  You should be getting your plans today.
Not knowing how you arrived at your 1.7kw figure I'll explain how we arrived at ours.  The method we use is to actually clamp an amp meter to the supply lines to the motor and measure the current flowing in the circuit.  Then we use the formula: P= IV to arrive at the power being produced.
When Breezy 5.5 is max'd out (actually when our turbine begins to limit the torque applied to the motor shaft), we measure 23 amps flowing in the circuit.  Using the formula above we simply multiply 23amps X 240volts = 5520 watts (maybe we should call it "Breezy 5.52").
The power produced by the motor has much more to do with the turbine driving it then the size of the motor (easy guys, I'm still talking about asynchronous generation here).  If you connect a smaller motor to Breezy's turbine, a 5 hp for example, you would be over driving the motor and probably burn it up shortly (regardless of what the motor data plate says).  This is so much a fact with wind power that you can almost determine the power capabilities of a wind turbine by simply looking turbine it's self.  When comparing Breezy 5.5 to other types of turbines consider that Breezy's turbine is turning (and pretty much held) at speed around 120 RPM and is a four blade turbine over 18` in diameter.
Gary, I see that you have referred to our web site as "should be looked at as another snake oil site".  I must say that I find that remark quite offensive.  And as for myself I would be quite sure of my facts before making such a comment especially if I were as ignorant of the principles of this type of generator as you would lead us to believe you are by your statements.
In contrast we have done our research and also relied on the research of others to present this turbine and the plans for it.  But you don't have to believe me. In 1974 at the Technical Institute of Vaasa in Finland a study of how "squirrel cage" 3-phase motors excited and driven as generators behave unexpectedly under different wiring and load configurations.  I believe some of the results of that study may still be available at: http://www.saunalahti.fi/elepal/moottori/gener_e.html.  Also on a Danish website I have found an excellent description of the principles of asynchronous generation, you may want to take a look at this: http://www.windpower.org/en/tour/wtrb/async.htm .
Since I believe in the phrase "put up or shut up" I would like to extend an invitation to anyone wishing to see and measure the output of our turbine for themselves. We're located in central Kansas 20 miles south of Abilene.  My only request is that you call first so that we can schedule a time.  If you can't make it yourself and have a friend or relative nearby, we'd be happy to show them too.  You may find our contact information and a phone number at: http://www.prairieturbines.com
Re: 3-phase vs. single-phase alternator (3.00 / 0) (#19)
by eliyahu (eliyahu@godspot.org) on Sun Dec 16th, 2007 at 01:40:24 PM MST
Hi Tim My order for your book is in the mail. I don't think that Gary was intending to slur you specifically (my read anyway) just to offer a warning.
In our conversation you referred to Dr. Gary Johnsons(K.S.U.s)Wind Energy Book. He makes the observation that the third leg of the 3 phase supply can act as a voltage regulator of sorts to provide balance. He advocates capacitors and a resistive load but as you pointed out on the phone unless you have a run away the resistance appears not to be necessary.
"An induction machine can be made to operate as an isolated ac generator by supplying the necessary exciting or magnetizing current from capacitors connected across the terminals of the machine"
I note that you are gearing up the motor to achieve your speeds. Have you calculated what losses are incurred? Adding a 4th blade to your prop clearly helps with this. (Marcellus Jacobs liked a 4 blade prop)
Can you offer a general explanation of what your controller does?
Grid tie at this level appears to be much more economical, avoiding the battery's and then inversion. So I see you guys as providing economical wind power. Well done.
3-phase vs. single-phase alternator | 23 comments (23 topical, 0 editorial)
