Nice Science Fair Style Mini Mill | 21 comments (21 topical, editorial)
Re: Nice Science Fair Style Mini Mill (3.00 / 0) (#13)
by gregted (gregted@tpg.com.au) on Thu Feb 16th, 2006 at 06:52:10 AM MST
Nice one Ghurd...
I had to try this one and it turned out fine. My alternators are a bit different than yours but I simply traced the wires from the coils to the circuit board and soldered three wires on to them and then wired up the leds as stated.
Works fine but I noticed that two of the leds do not light up with the others. I suspected faulty leds, but they light up individualy from the wires from the alternator.
One thing I did notice was one of the leds seemed to light up when the wind speed was very fast, but it only lit up for a second and the other one was still out.
Curious but still a working wind generator from spare parts.
The next alteration will be to use some clear rulers and different coloured leds.
At Dick Smith Electronics here in Oz, they have multi-coloured leds as in red/green and red/blue and also three coloured ones that have three legs.
Might be an interesting effect.
Another idea might be a simple railway crossing circuit aka.. flashing alternating leds or simply flashing leds of different colours.
Question.... How hamy leds will these type of gens be able to support??
Great project for a rainy ( windy?? ) day!!
If I can build it, anyone can ;)
Greg.
Re: Nice Science Fair Style Mini Mill (3.00 / 0) (#14)
by ghurd on Thu Feb 16th, 2006 at 05:54:00 PM MST
Thats different Greg!
My first thought maybe a bad coil or solder connection at the resistor.  But both LEDs should light if one does.
The only thing I can think of right now is re-solder that pair and resistor.
Throwing out a few quick ideas...
Would the set not working be yellow, green or blue, while the others are red?
Red lights first. Yellow next, then green, blue and white.
Possibly the pair operating poorly are not reverse connected? That could have some strange effects, but they should still light.
The first thing after resoldering I would try is changing those LEDs and their resistor.
The frequency of these things is very high. I would not expect a 2 color LED to show 2 colors when it is up to full speed. More like both colors at the same time.
I believe faster blades, like short PVC Zub-Woofer style, to generate a much higher voltage. Maybe 4" dia pipe, and 3 at 18" diameter blades. Those really spin fast.  Then 2 series LEDs replace each single LED.  I'll let you do the metric changes.
I don't think there is enough potential for current flow to operate LEDs in parallel. At least not very well. These motors are better for voltage than amps.
I will keep thinking. Let me know what was wrong.
Big Fun with little parts.
Nice Science Fair Style Mini Mill | 21 comments (21 topical, 0 editorial)
