then look at his pic . http://www.windstuffnow.com/main/darrieus_type.htm ...it might be best to print out this picture and study it.... (DSC00002) from the bottom...the part that 2 rods are stuck into ...that part is attached to the drive shaft ..(vertical) Okay next round part...is an eccentric...the center hole turns freely on the drive shaft... those rods on it, go out to the swivel part of the vanes...the vanes swivel as they rotate. There is an offset hole...a little shaft is fixed firmly with setscrews. A block slips over the stub shaft...it is fixed firmly to the stub shaft also ...which is fixed to the tail shaft... I didn't understand it at first either, but it is very simple once you grasp the concept....isn't it Ed? ( :>) Norm. ( :>) Norm
